Guest viewing limit reached
Wet vac !!!!!!
View the thread, titled "Wet vac !!!!!!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Craig Carter
Hi guys does anyone have any suggestions !!! I've currently got a KARCHER wet and dry vac but for the second time mine is playing and need a decent replacement !!!
not sure what's happend but when I turn it on not only does it spill water out everywhere but makes the most horrendous noise ever !!!! It's been back to KARCHER once , SO where's the best to find one that I won't experience problems with ??
Thanks (very annoyed Welshman )
.....but makes the most horrendous noise ever !!!!
Most die in a similar noisy death ,when water+Grit get in bearing ,wearing into a larger diameter and doing the spiral of death/Grating the impeller on the casing.
Or a loud_buz = Jammed
Water in impeller usually makes revs suddenly dive down -Turn off Quick !
(Last death was a Wickes now have Earlex Both same cheap & Noisy)
Vac King from machine mart, cav255, think thats the model, nice stainless drum and good motor. £60 ish
Reply to the thread, titled "Wet vac !!!!!!" which is posted in UK Plumbers Forums on Plumbers Forums.
Craig Carter,
TBServices,
