View the thread, titled "Wet yorkshire fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Justin R
my shed recently got flooded and I didn't notice a box of yorkshire fittings under some other stuff.
Sat there a while in the wet and now they have some white gunk inside. Looks like it's leached out of the ring of solder.
Can I still use these or will they give me trouble?
Cheers
Justin
Clean them before fitting them cant see any issues coming from them if in doubt use one on a test rig and try it
Have been given a few Yorkshire fittings that have lying about for years that were like that.
Can be hard to clean, but use some emery cloth to clean them and if you see the copper sparkling, it should solder okay. I would use them on less important areas, like on expansion pipes above water level.
Ha ha ok I guess they're alright then.
Thank you all for your advice.
Justin
Reply to the thread, titled "Wet yorkshire fittings" which is posted in UK Plumbers Forums on Electricians Forums.
