View the thread, titled "what and where is the 'boiler CH service valve'?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Reviewing the Valliant ecoTEC install manual, and steps noted in this book for re-pressurising the internal expansion vessel states the following
- Ensure the boiler CH service valves are closed.
- Release the pressure from the boiler.
- Remove the valve cap from the expansion vessel charge point.
- Check that the internal charge pressure of the expansion vessel is between 0.75 and 0.9 bar (if the pressure is lower than this the vessel should be re-pressurised using an air pump
- Refit the valve cap
- Re-pressure boiler and heating system
what is meant by the 'CH (Central Heating) service valves' - would they by many on a system or just one place to go? is it boiler specific?
thanks
Looks like they're wanting to check or repressurise the internal vessel, which unfortunately is a Gas safe registered area only.
Leave “well alone” , it could all “end in tears” .
Especially when you turn the valve back on .
thanks
Please leave you boiler alone unless you are gas safe registered. If you are please PM either @Harvest Fields @ShaunCorbs or @Riley with your details. Otherwise please get a professional in to do it.
Reply to the thread, titled "what and where is the 'boiler CH service valve'?" which is posted in Boiler Advice Forum on Plumbers Forums.
