View the thread, titled "What are my options with my bath?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I had a combi boiler installed 2 years ago. I now have leaking taps on the bath it’s leaking down the copper pipes making them green. These pipes are both 22mm and I get awful water hammer on the cold assuming that’s from the pipe going 15mm to 22mm!
The taps are at the back and centre on an external wall. Is removing the bath and replacing it with new taps/pipes an option?
Bathroom is fully tiled all over with no spare tiles.
really can’t afford a total bathroom refurb but something needs doing. Any ideas?
Assuming that the two pipes which are visible under the bath are the ones which feed the tap.
You could cut a new tap/ pair of taps into the front right corner of the bath and feed it from those two pipes, in the process cutting off the feed to the existing tap.
The existing tap could be left in position, or cut off from above and tap hole stoppers siliconed into position from above.
This is probably the cheapest option.
It doesn’t look like there’s much access, so I’d be looking at access from below (eg cut a hole in the ceiling - if it’s viable?) to renew pipes, removing bricks - no easy task, or what Ben-gee has suggested.
Thanks guys. Didn’t think about a second set of taps but that might be an option. Going in from underneath would mean the ceiling and the bath under the floor being cut out as I think the previous house owner did just that hence our pipes seem to do a u turn.
[automerge]1601204329[/automerge]
Hubby is a very happy man right now at your idea!! Thank you have just well and truly saved our bacon!!!
If the pipes are too old just replace it because the chances of the leak are high. While you replace the pipes with new one consider some facts to avoid copper oxidation.
1.Install a calcite neutralizer tank, or a soda ash feeder to raise the pH to 7.0 to 8.0 to correct for low pH and increase the alkalinity in the water.
2.Install a phosphate feeder before the copper piping
Reply to the thread, titled "What are my options with my bath?" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
bath
Gem1983,
DonaldKBradley,
