Guest viewing limit reached
What bits to buy for a core
View the thread, titled "What bits to buy for a core" which is posted in UK Plumbers Forums on UK Plumbers Forums.
the only other thing you might need is an extension bar depending how thick ya walls are unless you do half inside and half outside oh and a sds drill 🙂
is the core drill arbour the bit which the core attaches to ? if so then it should be enough to get through 210-220mm brick i reckon
you shouldn't cut cores bigger than 70mm with a sds drill. Really you need a dedicated core drill - unless you want to kill off your sds before its time . . .
Reply to the thread, titled "What bits to buy for a core" which is posted in UK Plumbers Forums on Plumbers Forums.
marsaday,
justlead1,
