View the thread, titled "What is causing water hammer in my flat?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello
I wonder can anyone shed any light on what is becoming an annoying problem?
I had a new stopcock installed in my second floor flat a year ago. This was intended to stop water hammer which had been taking place. However, recently the water hammer has returned and from what I can tell it occurs when water is used in the flat below mine, and possibly in other flats as well. The noise is a banging or crunching of metal sound and it can be quite loud.
But, I cannot work out is why this is happening, and this is where I seek advice. Could the water hammer, if that is what it is, be the result of a vibration in the pipes because of water usage, water pressure or an air gap? If this is so, where might it be occurring?
Water in my flat is delivered via a dedicated pipe which rises through the building. This pipe is, as far as I know, isolated from the other flats which have their own respective pipes. Whether these pipes branch from a common supply which connects to the mains, or if they are connected directly to the mains, is not something I know.
Any advise would be appreciated ...
Mr Gwent.
How old is the block of flats? What makes you think you have a separate riser? That should mean less noise from neighbours and exact point of connection below is not likely to make much difference.
Hearing neighbours turning off taps is common but that's a brief sound. Banging in pipes more serious as you've
experienced before but crunching metal sound?
The block of flats is just under thirty years old. Each flat has a separate riser because my second floor flat's water supply was turned off from the ground floor by the plumber who carried out the aforementioned work for me a year ago. The plumber identified three riser pipes behind a ground floor access panel serving my flat and the two immediately below mine. Moreover, the cutting of the water supply to my flat did not affect the two flats below mine.
The banging noise could result from the turning off of taps by neighbours downstairs but why should this affect an independent system? Perhaps the plumber calling early next month will be able to suggest something?
Reply to the thread, titled "What is causing water hammer in my flat?" which is posted in UK Plumbers Forums on Electricians Forums.
