yeah thanks I read the document H and have worked to go with the same angle as the boss adapter is set too ( 2.5 degrees ) so I've got a 40 mm pipe and a 50 mm pipe one above the other20mm-25mm a meter is normal you could go as low as 15mm a meter if you have to but no less
cheers brilliantYep sounds ideal
Reply to the thread, titled "What is the fall for connecting a 40 and 50 mm Drain into a soil pipe" which is posted in Boiler Advice Forum on Electricians Forums.
