R
ringi
I am playing with a system design that will need the output from the boiler at 60c; however I can get the return down to 20c or below. I can regulate the output temperature by controlling the flow rate through the boiler. E.g using a 32KW boiler, I will need a flow rate of 11 m/s.
Would a normal system boiler cope with this, or is the dT too high for the boiler to be happy?
Given an output of 60c, how much better does the boiler condense with a return of 10 rather than 20?
If I was to run a 40KW boiler at a flow rate of 11 m/s would I get more condensing then using a 32KW boiler?
What flow rate do the internal bypasses in boilers tend to be set at?
Many thanks; sorry I could not find this basic information for boiler spec sheets.
