What is this below the automatic air vent valve?
View the thread, titled "What is this below the automatic air vent valve?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
F
fullel
The (apparently rotated) picture shows my badly scaled up automatic airvent valve just a few cm downstream from the pump. I have some water hammer (hydraulic shock) when the pump goes off and this scaled up air vent is my prime suspect. I am ready to drain the system down and screw this old vent off. By the look of the amount of nipple, I will have to cut the olive off, clean the pipe and replace with the new compression 15mm auto air vent.
What I don't know is what the object is immediately below the air vent sticking out to the left and whether I need to replace that too. Is it a manual bleed valve for example?
Thanks.
I can't see a prv valve, looks like it was once a tee piece & its been capped off maybe?
its best to fit an isolater before an auto air vent, saves draining down to change or service the air vent!
It all looks a bit old and crusty to me - I would be tempted to
cut out as much as I can see on your post and replace the prv and
mt cock all in one go.
Now is the time - summer bbq season dont wait till November CHK
Thank you. So it is a manual version of the same thing? Twist to relieve pressure and retighten?
No, it's automatic but I've seen the type you have there fail too often. Don't trust them.
It's definitely a PRV buddy, I agree with the isolator but it must be fitted so it isolates the AAV only.
Looks like a pain to fit an isolator because there's little room without taking off the T going to the right with its own lever ball valve (primary feed to second HW cylinder) and little room below that where it all gets a bit 32mm.
So why are there two valves? The normal one is a 6 bar trigger and this little thing is 3? Is there any reason I can't leave the suspected broken spring safety valve and put another new one on 15mm above it with the new auto air vent on top of that? I'm a bit worried that trying to replace the SSV will lead to a cascade all down the tree requiring repiping the 22mm piece to the right _and_ the 35mm section and...
Crops spot on
Used to fit loads of these years ago mainly above heat only boilers. You can adjust them, but they always leak over time and need replacement.
AW, as Crops says they are Tosh, nothing to them, when they blow off where does the water go on the floor, on the OP photo wash the wall down, hell that's before the Ark design, can we see one in bits and learn the folly of our ways..:rofl: you can just imagine one of those in the bottom of a Kellogs Rice Crispies
Fullel,
Where is your 6 bar coming from, surly not domestic.....
Left over from old system, probably solid fuel BB, what boiler do you have now ? if you have a pressurised system you will have a more up-to-date PRV, so you can cut out and remove this old fitting
Ah yes. Well, still don't know why there are two. So, just replacing the top one should work then? I kind of thought the water hammer was caused by air not being able get _in_ to fill the 'vaccuum' when the pump stops.
The top one is an Auto Air Vent. It vents air out of the system automatically (see what I did there?) but doesn't. or shouldn't, allow air back in.
The bottom one is a Pressure Relief, or Safety, valve. It automatically releases pressure over a given point which, in your case, is 3 bar.
Neither the failure, nor the operation, of either component would result in the noise you say you have.
I'd suspect a sticky flapper type none return valve to be honest.
They have two completely different yet vital functions
Reply to the thread, titled "What is this below the automatic air vent valve?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
fullel,
happyflyer,
