View the thread, titled "What is this pipe for?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
shapingthings
In my shower room there is a pipe that runs down from the ceiling. The waste from the sink feeds into it. It is a single floor flat and the pipe appears to have no use, there is not flat above mine. No water appears to run down it.
What is it for? Do I need it because I would like to remove it. I can send pictures if this helps.
Thanks. 🙂
Thanks. 🙂
sounds like an internal stack to me😎
Hi. From what you describe it may well be a vent pipe, that is present to maintain air flow within the soil/waste and drainage system. It not a good idea to cap it off. As it may result in sewer gases being allowed into the building via sanitary fitting.
Reply to the thread, titled "What is this pipe for?" which is posted in UK Plumbers Forums on Plumbers Forums.
