View the thread, titled "What is this type of WC flush?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
cattlegrid_79
Hi all
As a DIYer, a friend asked me to take a look at the flush on one of her WC cisterns as it had stopped working, but i had not come across this type before and would appreciate some help.
It's an en-suite with a push button flush on the wall next to the WC. This connects to an air tube that goes through the wall to a cistern which is in the utility room.
The air pipe is connected to a plastic, corrugated diaphragm type plunger, which in turn sits in a platic frame across the cistern and rest on top of the siphon unit.
The idea is that when you push the button, the plunger/diaphragm moves out and pushes the siphon unit down, starting the flow.
This has stopped working. The siphon unit works fine when operated by hand, and I have checked the diaphragm/plunger and there is no air escaping there. The air tube seemes sound so I just can't work out the problem.
The plunger/diaphragm does move slightly when the button is pressed but wont appear to move enough to push the siphon unit down.
Any ideas?
Sorry for the long post, but wanted to try and be clear.
Its called a drop valve mate look at screwfix 42562-95 or 43148-95 if its on a close coupled wc best change the donut washer as well, hope that helps.
Have you tried cisconnecting the tube from the button and then blowing down it.
BTW the cistern sounds like it might be a Grohe
Thanks for your reply. Now, I know i'm not great on computers, but why can't I find these items on the Screwfix website using the product codes or the term "drop valve"?
Do you think the whole unit needs replacing?
Thanks nick. Yeah, when you manually push the drop valve down it flushes fine. It's just this pneumatic link from the button to the bellows. Couldn't find any air escaping anywhere on the line - tried blowing through it too, but can't seem to get the bellows to move enough.
Maybe the air line is blocked. Might be easier to replace the air line, bellows and nipple if it's not too expensive. Or i might be hours trying to work out why this is not working!
The parts are here on the Lunn's page: [DLMURL="http://www.lunns.net/cisternspares/"]S.A.Lunn (Specialist Plumbers Merchant) Ltd[/DLMURL]
Items titled "Dal 5443492 flush valve" and then just below that is the air bellows and nipple in the cradle. This links via the pneumatic air line to a wall mounted flush button.
i counted fortyone different flush mechanisims on that page when we probably had a max of six diferent syphons and they call it progress?
Hi Cattlegrid I hope I have not misled you regarding the part just noticed my screwfix catalogue is winter 2008, I dont get it anymore since I was banned 🙁. the buggers wont even let me buy from them!🙄
No, that's cool Winston. Thanks for the help. Gave me a starting to point to know what to investigate!
I won't ask about Screwfix...!
there has to be an entertaining story here winston ive been banned from a few pubs in my time but how the feck did you get barred from screwfix????
Well upset a few of the members there as they dont like the fast trackers 😀 I Did go a bit over the top I guess. And I dont think my friend (Admin) at screwfix like me sending her the plumbers song 😕 I thought it would bring a smile to her face returning from holiday 🙄
Anyway back to the drop valve Wirquin do a very nice kit which includes the do nut washer and inlet valve, costs a bit but is very good.😀
Wish I new how to post the plumbers song on here but dont want to upset the moderators as they are a good bunch, though its not offensive.
Though my misses gets a bit uptight if I play it on the surround sound 😀
The plumbers song 😀 at YouTube-CockSparrer-I fit central heating [with lyrics]
Reply to the thread, titled "What is this type of WC flush?" which is posted in UK Plumbers Forums on Electricians Forums.
