View the thread, titled "What make of shower is this?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
stumped
Hi does anyone know what make of shower this is? (photos attached). It has no identifying marks anywhere on the outside or the inside. Thanks.
Hydro flow aqua dart
No longer avalible
uses mains cold water and hot from tank,idea is pressure of cold mains drags hot through to shower head
nearest replacement using same set up is the trivi boost
Imho
thanks puddle/tom that's helped a lot. i'm not a plumber and was stuck after hot water wouldn't stop flowing & replacement shower (mira) had no hot pressure. still have hydroflo in storage & see some people fixed problem by stripping down, soaking in vinegar to get rid of deposits & lubricating spring mechanism with silicon grease. or i can fit a trevi boost. or a combi boiler! appreciate your help fellas.
Trevis are okay but really need regular maintenance. I cleaned one out got it working then the flow dropped off again 10 minutes cleaned what I thought was okay and it worked fine still does according to the client who I see in a local shop.
Reply to the thread, titled "What make of shower is this?" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
