M
Marty32
Evening all
Just looking for some scenarios so I don't ending up making any mistakes out in the field?
Cheers
Mar
Never seen it happen but I suppose if the cold feed and vent were frozen and you drew off water the negative pressure created could allow the cylinder to collapse.
I'm not sure you'd get the required pressure from just drawing water off (though I'm not saying it can't happen). I think it's more likely to happen as the water in a bunged cylinder cools.
Possibly, but it is atmospheric pressure that collapses the cylinder so it wouldn't take much of a differential pressure to do some damage to a copper cylinder.
Saw this happen when i was an apprentice many moons ago,un-froze the expansion and re-filled,it opened up again but with a load of creases,it made everyone laugh in the brew cabin for many a year
I've seen one split where the open vent and feed had frozen and the boiler came on. Made a right mess. After fitting a new cylinder it took me hours to defrost the pipework in the loft to fill and test the new cylinder.
Best way to get the lagging off is to cap the cold feed and stick a hoover on the top. The cylinder will collapse and the lagging fall off. Assuming you haven't had to smack a hole in it to syphon the water out where the drain off doesn't work. I just jump on them in this instance.
I guess if you had a blocked vent pipe and blocked feed then tried using a wet vac to suck the blockage through you could end up collapsing the cylinder?!
It can and does happen. I've seen it twice. the first was caused by frozen pipes the second i did when syphoning a cylinder (it was coming out)
Just needs the right circumstances, which with the grade of so called plumbers now doing this job who don't even know the absolute basics and fit vented cylinders with no expansions because they are thick as mince, it will.
Also saw one with the rse turned out due to frozen pipes too and the immersion being switched on.
Here is the one i collapsed when syphoning. The hose in the draw off was pretty tight fit but not airtight. Well i would put it up if the thing would let me!
I'll try it again later
My mates cyl imploded on Xmas eve a couple of years ago. Can only imagine that the vent was blocked with ice, and when the pressure built it it blew the ice plug and caused a vacuum. Only time I've ever seen it.
Sent from my iPad using Tapatalk HD
It's quite common where I am to have water cylinders collapse, especially the older copper type. There are usually two anti-vacuum valves fitted at the cylinder to prevent it but sometimes they stick closed with limescale or sometimes they're incorrectly installed or missing entirely. Here's a photo of my cylinder, you can see the two vacuum valves on stalks at the top of the pictures.
Yep, the Tree Of Knowledge is a good set, unfortunately my kids aren't interested in any learning aid that's not electronic.
About 20 years ago the cylinder developed a leak on one of the swaged seams. When I dismantled it to weld it I upgraded the insulation to closed cell pellets and added an internal reflective blanket so the outer casing is stone cold.
It's a shame - these series and other Knowledge series were a good source of information back in the day! I think mine are confined to loft too!
