BenC
a friend of mines family asked me if i could plumb a boiler in for them, i said i could but i couldnt commission it ect so they were happy with that i told them i would work for £15 an hour as i was doing it after work (from my main job).
now they had done alot of work themselfs they had done the main runs and connected most of the rads into the main runs but not made the connections on some of the rads, so basically ii had to finish the connections on 2 rads and also completly connect 2 rads into the main ring as they had ran out of pipe when they did it, also completly plumb the boiler in as the flow and return
pipes had be left just in the attict above the boiler and not brought down to the boiler. also had to bring the cold main to the boiler and run the hot out and the prv pipe.
as they had done the main runs themself i decided to airtest the system which led me to find various leaks on their pipe work which obviously i had to trace through the 4 differnet atticts in the house checking all the joints ect got them sorted after a few hours got it all working they were happy i only charged them £270 for this as it had taken 18 hours all in all. now thye got some one else into commision it this weekend and that guy has told them ive riped them off what i had done should of only taken 8 hours and he would of charged £140 to do it and that price included commsioning the boiler, now my mates parents are saying i have conned them and my mates being a right t**t towards me.
so summarise i
*basically connected 4 rads up 2 of which were half connected and the other 2 had no pipes going to them atall
*run the flow and return from the attic to the boiler below
*brought a cold main accross to the boiler
*and run the hot out from the boiler and connected to the old pipework
*connected all the flue etc up to the boiler
*run the pressure relief pipe out from the boiler to outside, had to obviously drill the hole for this
*pressure tested the system and sorted out the leaks the customer had on the pipe work they had installed themself
* filled the system up to find another leak on the boiler where the customer had fitted the bungs in the side of the boiler but only put one turn of ptfe on the threads so drained down sorted them out
* re filled the system got it all fired up for them and working fine ready to be commsioned
which took me 18hours and i charged £270 would you say that is fair
how much would you guys charge to do what i have done?
sorry for the rant but it had really ****ed me off today having my mate calling me a conn artist, im wondering if the guy who commisoned it only thought i connected the boiler up and not done all the other things i listed.
so summarise i
