Danv44444
Hi guys I went to service an ideal deal logic 30kw today. I did the service analysed the flue and everything was fine apart from the fact the vertical flue was only 100mm away from an adjacent wall instead of 300mm as it should be? I informed the customer that it was wrong and filled out the at risk paperwork and got it signed etc. the trouble is there isn't really any other way to re route the flue so I left the boiler up and running. Is this ok? The flue looks fine and and is well supported. It goes up through a glass roof and would probably need the roof to be altered to change it?
Id appreciate your thoughts.
cheers guys.
cheers guys.
