What you imagine when an automatic air freshner goes "pfft"
View the thread, titled "What you imagine when an automatic air freshner goes "pfft"" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
WaterTight
Subscribed
I had gone in to a flat with the developments concierge one day and one went off just as we passed it was high up on the shelving unit, we both cra*ed our self and hit the deck at the same time. LOL
Is a nervy time when filling up, my dad has got the best attitude, just goes for it and doesn't give a sh*t, doesn't check until up to pressure. Guess that's how you get when you've been doing it a long time.
when a gate valve on the cold feed or stopcock doesn't quite shut of and you open the downstairs tap to take the water away while you work upstairs and the customer turns it back of when you've cut the pipe and all of a sudden got water coming out where you don't want it upstairs.
i know the answere is to change the stopcock/gate valve but on the smaller job it's hardly worth it when it lets by only a little, I kno someone will disagree with that.
Drilled a hole in soil stack other day for strap boss, didn't realise customer had come home and managed to flush toilet as just had drilled hole, got some splash on my hand as I pulled it away quick,
niceeee.
Reply to the thread, titled "What you imagine when an automatic air freshner goes "pfft"" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
WaterTight,
josh,
