View the thread, titled "whats in your toolbox" which is posted in Plumbing Tools on UK Plumbers Forums.
Billy Bob Bob
we are always being asked what tools do i need,so decided to remove all the pipe,rubbish etc out of my toolbox before going back in to work tomorrow this is just a basic day to day kit needed for a plumber/gas engineer thats without sds drills,bat drivers and all the other stuff we use,its a expensive profession tools (WinCE).jpg
I've got differnet toolboxes for different jobs, got my service toolbox with screwdriver, manometre, grips, spanners, LDF etc in and a box for installs with cutters etc in. Anything else I need is all stored in the van and I know where everything is so it takes less time to find.
One of the best things I have got is my tool wrap that has a few screwdrivers a small pair of grips, a selection of fuses and various bits and bobs I need to take a boiler etc apart to have a look. I use this on breakdowns and have it in my hand when I knock on the door. Its amazing how many times I can complete a job only using this tool wrap and not need to go back to the van to collect soemthing else.
i am going to do the same,getting a bigger van so more room,just weighed that lot toolbox included its 4 stone no wonder my wrist keeps playing up LOL
my tool box weighed a bloody ton, was probably not far off 30 kg. Now I have 2 large boxes, a small tool box for a handful of tools and a small bag. I mostly use the small bag.
i seem to have the same idea as villa, i have a, what i call my gas box, manometer l.d.f.meter caps etc, and day to day box, keeps the weight down , i have also a box with my soldering gear in,works well for me,could do with using them more often than present, i do hope things pick up.
hope work picks up for you desrob
i have a tool box for bigger tools hammers hacksaw 25mm drill bits etc and a fatmax tote bag for smaller tools i also have a tray for small jobs an when working in lofts, similar to this but cheaper [DLMURL="http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=11247876&fh_view_size=10&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=tool+tray&fh_eds=%C3%9F&fh_refview=search&isSearch=true"]Stanley Tool Tray, 1-94-220[/DLMURL]
my tool bag contains: bahco 8 and 6 in wide jaw adjustables, water pump pliers, and a baby set of rothy pump grips - great for doing the nut and cone up tight when fitting a shower. side cut pliers, pliers, long nose pliers, 3 different sized pozi drivers, 3 different sized blade drivers,pipeslices 10 - 28mm, tape measure, boat level, big level, multimeter, juinor hacksaw, hacksaw, 24 mm spanner, small socket set, 17mm ratchet spanner, olive splitters, led torch, head torch, lighter - just in case. stanley knife, stab saw. Hep cutter, oh nd stumpy philips and blade screw drivers. towel, and most importantly a roll of loo paper!
the 24 mm fits a 15mm comp nut, the comp nut has a O/D of 24mm, this spanner has a long shank so great for undoing comp fitting that have been on for a long time. the 17mm ratcheting spanner is useful for doing up the nuts in a basin fixing kit, i always hang my basins with a fischer bolt fixing kit and was always a PITA to do up the bolts took forever, till i came across the ratcheting spanner, its my trade secret on my site!!
what did you use if you were putting corner basin in.?
Reply to the thread, titled "whats in your toolbox" which is posted in Plumbing Tools on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Billy Bob Bob,
SafeGasInstall,
