View the thread, titled "what's my problem?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
L
Legume
Had new valve power head and new dual channel clock supplied in November. Current problem is that when hot water timer comes on the central heating comes on too - even though I've set clock on CH to off position. It's summer (almost) & I need hot water in home but not accompanied by central heating. ???? HELP.
if all worked ok previously then its a wiring issue, if its always been like that a system design issue youll have to live with till you change the boiler probably, If you were ok before and youve a three port valve, then the valves probably seized and needed replacing when the head was changed
Reply to the thread, titled "what's my problem?" which is posted in UK Plumbers Forums on Electricians Forums.
