As part of a loft extension 16 years ago a couple of 600mm high x 700mm wide radiators were installed. As a result of poor flow rates in the loft these radiators no longer warm up and I'm in the process of flushing through the pipes, which has so far removed a lot of sludge. The radiators themselves have also been removed and flushed through and again there was a lot of sludge in them. See my other posts for details if required.
For some reason, the lockshield valves are connected to the radiator using 3/4 inch(?) connections, whereas the TRV's are connected using 15mm connections. I've had to remove the valves to enable me to flush the pipes so plan putting on new valves and will use 15mm for both.
Although the radiators have been flushed outside, I'm wondering if I should take this opportunity to replace them. Googling suggests radiators should be replaced every 15 to 20 years, so on that basis it would seem to be the right time, although the radiators in the rest of the house have been in since the house was built 21 years ago (apart from a couple that had to be changed). Visibly, there's nothing wrong with the outside of the radiators and I would be getting replacements that looked similar and minimised the hassle of fitting i.e. the same size.
I've read that other reasons for changing radiators is because modern radiators perform better! The existing radiators appear to look very similar to modern radiators so not sure how that would be the case. I don't know what brand the existing radiators are, but they are Type 11's (1 panel with fins).
My current motivation for possibly changing these radiators is because they are disconnected, I'm changing the valves anyway and there is a lot of sludge in the loft pipes, so I'm assuming this has come from these loft radiators, but I'm not sure as it could have found its way around the system and settled in the loft pipes due to the poor flow.
So, would there be any benefit in changing these two 16 year old radiators? Are "modern" radiators really that much better?
PS. The last radiator I changed due to a seized bleed valve was replaced by a Quinn round top radiator, which used less water, although I do worry that the reduction in the internal volume of the radiator may also allow it to sludge up more easily. Quinn appear to have gone out of business, so are no longer available.
