View the thread, titled "Where is my filling loop?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I need to pressurise my Vaillant ecoTEC plus 618 Boiler, but can't find the filling loop!
It's not under the boiler itself... (IMG_1696.jpg)
And I'm uncertain about the pipes around the water tank upstairs (see pictures attached) -- can you see anything there?
Where do you think it could be?
Here is to understand the set up:
This is the inside of the cabinet below the sink (it's a mess due to the double sink, the insinkerator and the hot water tap/tank!)
I'd vote the the above, black knob should be on the lower one, on the underside.
Probably one of these or similar;
https://www.NoLinkingToThis/p/combi...Vw7HtCh2uHAnjEAQYBSABEgIt-_D_BwE&gclsrc=aw.ds
Flat head screwdriver in this part, turn a quarter turn. See if the pressure goes up. Once at about 1.2bar. Turn it back to where it is now. (Hopefully this is it)
Reply to the thread, titled "Where is my filling loop?" which is posted in UK Plumbers Forums on Electricians Forums.
