Spout will probably cost you £30-40 new tap £35
Ok, but where do I buy this particular type of spout? "notjusttaps.co.uk" do a similar spout for like £25, but I dont know if I should order it (are these a generic type fit on the spout base?)
ideal standard!
harsh cleaning chemicals have caused the damage.
No each manufacturer will use their own, you will have to find Manu then see if they do spares
Not worth the expense just replace the tap, Bristan have a 5 year warranty, due to age you Proberly wont get a spout for it, only other option is to get it re-chromed .
Just read your other comment ! if you are in a rented property its not down to you to replace it, unless you have damaged it !!
Landlord blatantly refused..Ah joys of living in London
Provided the tap works, and the damage is only cosmetic, the landlord has no obligation to replace or repair it.
However, any sensible landlord would replace it as silly things like this make a place more difficult to let. He / she might be losing £20 per month in rent for the sake of changing the tap. Not good economics.
Reply to the thread, titled "Where to buy a Replacement Spout for Kitchen Mixer Tap?" which is posted in UK Plumbers Forums on Electricians Forums.
