View the thread, titled "Which 110 chamfer tool?" which is posted in Plumbing Tools on UK Plumbers Forums.
Interesting suggestions
Doing a few, but would have to think carefully about £200 tho !!
File or grinder never do a really nice, uniform job and my 4' grinder normally carries a cut off wheel so do it's change wheel or grind with a cut off...
Never seen that type before. Shame there's no YouTube from the mfr. Most put promo vids up - nerrad/rigid etc
[automerge]1596650596[/automerge]
Yes, just seen that nerrad actually do one like that - chamfer and cut
You can get it perfect with a file, what you on about!!!!!
Nice square cut with a saw, file all around at an angle, finish off with some 120 grit if you want.
Come on, we’re skilled craftsmen after all !!!!!!.......
Yes you can but it’s time can cut and finish off under 30 seconds
Cut and File would say around 2-3 mins over a few joints it adds up
Looks like a beautiful cut and chamfer but if you're cutting a long section in half you wouldn't be able to keep your hand on the handle as you go round and would have to keep swapping hands or letting go and bringing the cutting hand round the other side of the pipe. (If that makes sense)
[automerge]1596894527[/automerge]
Seems like a bit of a faff if they say it needs lubricant.
I've always used a file or some kind of abrasive - 40 grit does ok. When you've got a fair few joints to make then you start to wonder "isnt there a better way?"
Bit like the plastic waste pipe slice things from rothy when they came along I thought they were unnecessary but then I used one and the speed, accuracy, lack of swarf and burr was an eye opener and now I wouldn't be without.
[automerge]1596981760[/automerge]
I think they include lube for the fittings when you push them together
I think you are right, it looked like like some kind of cutting oil type of deal
Reply to the thread, titled "Which 110 chamfer tool?" which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
WC1
Joined
General Plumber
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
tool
WC1,
WC1,
