View the thread, titled "Which Centralling heating plan?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Y
yrob
I've recently had some problems installing a new timer switch but after some digging have come to the conclusion that I'm not sure which Central Heating plan I have, i.e. Y, C, W etc. I have the following:-
Honeywell ST6400 timer
Honeywell v4043 zone valve
Room Stat
Cylinder stat
Ravenheat CSI Primary boiler - requires pump overrun
Pump is next to the boiler and wired direct
Store hot water in loft - indirect I believe
I would be grateful if anyone could state which plan I have so I can then source the correct wiring diagram for the Control center. Many thanks in advance.
If the pump is wired direct from the boiler then it must be fully pumped which would point to an S plan but you need two zone valves for that. There must be another zone valve unless it is not wired to a plan.
Mike
Thanks Mike. Yeh getting a bit confused. There is def only one Zone valve and the wiring center was orignally wired with that but no pump overrun to the boiler. Any further thoughts??
The valve is under the floor on the upstairs. The boiler and pump are below this in the garage.
Reply to the thread, titled "Which Centralling heating plan?" which is posted in UK Plumbers Forums on Plumbers Forums.
