Guest viewing limit reached
Which system cleaner for 14 year old system?
View the thread, titled "Which system cleaner for 14 year old system?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
markyhud
I received some great advice on this forum in the past for draining down and refilling my CH system. However I am still having problems with air/gassing in the system. At some point in the next few weeks I'm going to tackle this and plan on adding a cleaning agent. I have been looking at Sentinel X400 and Fernox F3. My CH system is 14 year old, hot water tank in airing cupboard and f&e tank in the loft and it has never had a cleaning agent used. I am forever having to bleed the pipework in the airing cupboard in the summer and then in the winter when the rads are on all the air/gas collects in the bathroom rad. When I bleed the rad it spurts black water but then runs clear. All is quiet for a few days and then the gurgling/bubbling noise returns. I have no cold spots in the bottom of any rads so do I actually have sludge?
Which cleaner is easiest and safest to use that i can just run, drain and then refill. oh and which inhibitor should I use?
Thanks in advance
Fernox F5 Heavy Duty cleaner, Fernox F1 inhibitor, and fit a inline filter, but you could have other issues if you keep getting lots of air in your system.
Cheers. Just had a quick search and the F5 seems to be for use with powerflushing
X800 is the same. It's a more powerful cleaner that's all leave it in for a week.
X400.is only for systems up to 6 months old
Ok I'm confused as this is from sentinel's website
"Specifically designed for existing systems,
Sentinel X400 System Restorer is a non-acid treatment for cleaning older heating systems, restoring circulation to radiators and pipework"
and
"X300 cleaner helps to maintain system efficiency and conserve fuel.
  • Cleans new heating systems up to 6 months old"
:thinking:
I've also read that the X800 tends to foam and is hard to remove. I have to point out that I'm very much a novice but quite prepared to have a a go at stuff given the right direction. With this is mind which is easiest to use and least harmful to the system etc??
Use. X800 for pretty much every job . Have a few times used neat hcl. ( de scaling fluid)
Does not need to be used with power flush, just add it to system, keep in system for 7 to 10 days but you need to use heating F5 works better when hot, find with sentinel products you have to leave them in system a lot longer, used Fernox for years never had any problems, Why not just ring their Tec dept and have a chat with them, if you are not sure what to do ! get someone in, they can check out your system at the same time as to why you are getting lots of air in system.
OK so it looks like X800 is the way to go. Just a couple of things. There seems to be conflicting opinions on how long to leave it in the system so....... how long? I'm presuming it's best to circulate at highest pump speed and have also read to close off all but one rad at a time. Is this the case? If I do have sludge will it remove/suspend this as well as products that are specifically branded as sludge removers? (i.e F3 and X400)
I am concerned at the term "heavy duty" in the title of this product. As it seems to be stronger than the X400 can it lead to stress and leaks at any weak joints or is this not the case as it is meant to be non-acidic?
Sorry if these questions are annoying to you professionals out there
Fit a Magnaclean first and leave system as it is and run it then run it some more until Magnaclean is clean. Then flush out with water then refill and add 2l of x100.
Incidentally I see some eBay sellers are selling F3 and F1 at seriously cheap prices. Has anyone ordered from eBay? For the novice I probably wouldn't be able to tell if it wasn't the genuine product. What do folk think?
Yeah that is definitely an option worth considering. Cheers.
its probably a large companys van stock left over from jobs they never botherd using it on. If its old or been stored in cold for a long time its probably not worth the chance.
Reply to the thread, titled "Which system cleaner for 14 year old system?" which is posted in UK Plumbers Forums on Plumbers Forums.
markyhud,
AWheating,
