whistling boiler
View the thread, titled "whistling boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Boiler can whistle when overgassed. It will be cheaper for you to get a registered installer to check it than needlessly buy a new heat exchanger.
Which boiler model do you have?
To replace a heat exchanger could be a costly venture
Options (cheapset first) To add a noise silencer like a Fernox F2 to reduce noise.
Another option would be a powerflush of the central heating system, using a powerflush unit and chemicals like Fernox DS-40 and system neutraliser.... then fit a magnaclean filter (Professional or TwinTEch) 😉
its an old 1996 ideal elan 8kw. overgassed never thought of that, also the flow only rising to 70c which is why I thought maybe HE.
Reply to the thread, titled "whistling boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
dam,
yammas,
