View the thread, titled "Whistling noise on combi" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
andf380
I have to go and service a halstead combi boiler i think its about 7 or 8 years old next week customer says it is making a loud whistling noise as the heating comes on and then the noise goes away any ideas before i go and look at it
I was maybe thinking the combustion seals or maybe the fan
From my one time experience recently I can only suggest the fan, my boiler is 9/10yrs old and ended up the fan had rusted off the backing plate.
I assume this was causing the loud thud when the hot taps were switched off and the constant whining from being unbalanced and vibrating against the plate. It took a few days of the whining for it to eventually fail.
Thanks for your reply when i got there it was more of a clcking noise and sounded as it was coming from the pump as the noise carried on after i turned the heating down and the burner and gone out during the pump over run time any ideas on it
if its defo coming from the pump - take it off - check its moving round freely. if not new pump.
Reply to the thread, titled "Whistling noise on combi" which is posted in UK Plumbers Forums on Plumbers Forums.
