I have a Rayburn 308K oil burning stove (uses concentric wicks) It is fed from a tank which is around 3m (10ft) above the inlet of the stove. I have it around 20 years. Ever since I got it, if I run out of oil, the stove will not light after the tank is refilled. The only way I can get the oil to flow again is to disconnect the section of oil pipe between ball valve shutoff and fire valve and use compressed air to force contents of the pipe back in to the tank. Close ball valve and remove airline. When the ball valve is opened again the oil then flows freely.
My question is why does head of oil in the tank not push everything - air bubbles - whatever- through the pipe as soon as the tank is filled with oil? I am getting too old for fiddling with spanners valves and oil pipes in the confined space beside my stove.
