H
homeowner
It is a handbasin tap and i had a plumber out a few weeks ago. I suspect it may have been sufficient to replace the valve, but was told the whole inside needed to be replaced, which was fine. Anyhow the tap is now dripping again. What possible reason could there be for this? I have turned it off as tight as it will go.
Being told by same plumber i now need a new set of taps. Why would that solve the problem is valeves are what cause taps to drip?
Grateful for your views please
