View the thread, titled "Wickes cylinder stat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
stevehepp
I need to replace the immersion heater in a hot water tank, there is no boiler, and want to also fit a clamp on cylinder thermostat to make sure that the immersion heater does'nt over heat, as it has just done. The emmersion heater has three wire, L, N, and E. The Clamp on Thermostat has connections 1, 2, 3, E. As the immersion heater will be powered from a 13amp socket (on its own 15amp supply) any idea which wires go where?
Steve
the immersion should have a stat on it and an overheat cut out, so shouldnt be a problem, the one you are taking out, probably didnt have an overheat cutout so will of been boiling the water
Reply to the thread, titled "Wickes cylinder stat" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
stevehepp,
PETE 123,
