View the thread, titled "Will the faucet leak?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Morning all.
Novice question, please be gentle.
It I attach an irrigation timer to my generic single-lever mixer faucet in the kitchen, leaving the lever on (up), and having the water flow regulated by the valve in the timer, is there any chance that my mixer faucet will spring a leak at the mixing mechanism (cartridge?)?
I would go for plumbed in.
Know more about these units than I should one of my sisters is a garden designer sometimes get involved in her projects!
It's a temporary fix/hack to keep some potted plants alive whilst I'm away for a month. No outdoor tap, only solution is kitchen faucet hose adaptor (internal thread) and then the timer. Though I know less than the average squirrel so any help appreciated.
Absolutely! Decent pic of connection then we can adv
seems to be connected to both?
You have a spare cold water connection blue lever on valve. The thread on that is 3/4 bsp most of the timer units I've seen are same thread.
You're a true gent for this, thanks.
The spare blue connection ends rather inconveniently flush with the red tap, and there's not much give in the pipe.
Also, is there not a standard on/off tap setting across all taps. These seem all open, or closed??
Could I unscrew the washing machine from the join further back (left) and connect to that?
Reply to the thread, titled "Will the faucet leak?" which is posted in UK Plumbers Forums on Plumbers Forums.
