A
AndyC
Hey folks. I've drawn out a diagram of the system I want to fit in my static caravan. Will it work?
The idea is for a pipe stat on the boiler outlet to switch on the pump when the stove is on.
I also thought I would need a safety valve on the outlet to drain heat in the event of power failure but I'm not sure exactly how it would work.
The other thing I'm not sure of is how to join the rad into the system to take heat when the tank is hot. As in valves to use etc.
Any advice greatly appreciated.
