View the thread, titled "Wireless Room Thermostats" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
rob jefkins
Hi chaps,
I've been asked to fit a wireless room stat for a customer. I've not done one of these before. Are they easy to set-up and get going??
Cheers
rob
Hi chaps,
Cheers
rob
easy peasy just follow the instruction before you do anything read right through as on some the order in which you perform certain tasks is important in particular dont pull the plasic slips out of the batteries not that i did on my first one oh no not me
wiring is pretty basic stuff L N AND A SWITCH PAIR
they are easy to do,even easier if its a worcester boiler,straight onto boiler face,no l,n feeds
Cheers, but what is there to wire-up on a wireless stat?
Do you have to wire up a receiver box near the boiler?
Rob
Depends on the set up, one I did was easy only took an hour, took off the old stat customer didn't want any more decorating to do so put the relay box there. Wireless room stat went into the living room.
Next one had to wire it directly into the airing cupboard followed destructions on zone valve.
However, the next one on a gravity system, thats a whole other story......
you can get wirless cylinder thermostats,for anyone who is converting gravity system ,fitting motorised valve near boiler and difficult wiring run,cost about £100 🙂
Cheers, but what is there to wire-up on a wireless stat? Do you have to wire up a receiver box near the boiler?
The receiver does need 230v to power the electronics. It can be either near the boiler or near the wiring centre for the motorized valve.
The transmitter (control unit) is battery operated.
Reply to the thread, titled "Wireless Room Thermostats" which is posted in UK Plumbers Forums on Plumbers Forums.
