Guest viewing is limited
View the thread, titled "wobbly D shaped toilet seat" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
ruthlevy
I have a top fastened D shaped toilet seat with no access to any fixings under the bowl. The plastic screw thread on top which holds the pins in the seat has lost its thread and I can't get it out to replace it and the seat has been wobbling for 2 years. Can anyone help with suggestions. Thanks
welcome along.
you either make access by removing the wc or panel behind if applicable.
or you cut drill/cut out the existing and replace with a seat that has fixings that go in from above.
Reply to the thread, titled "wobbly D shaped toilet seat" which is posted in Boiler Advice Forum on Plumbers Forums.
