View the thread, titled "wood boiler stove installation" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
lennox
Hi
I am going to install a wood boiler stove for central heating and hot water. I have the instruction manual which states " A safety relief valve should be fitted to the expansion pipe close to the boiler"
Can anyone explain exactly what the safety valve is and how it would work in this setup.
Lennox
safety valves are just what it says on the tin, if you dont understand what they do, DO NOT even think about installing your own system, get a pro in and if you want to save money ask if you can give a hand.
that type of sytem could end up with your missus opening a hot tap, pure pressurised steam coming out, suffering nasty burns, end up in hospital and death.
dont muck about. get help.
shaun
If a fault occurs such as the expansion pipe becoming iced up in the Winter and the boiler cold feed gets iced up as well. The safety valve would open up and vent out to reduce the pressure.
You got to remember a solid fuel boiler is not made to instantly shut down like gas or oil. It takes a long time for it to cool after its auto damper has closed. So by the time you noticed a problem with the expansion pipe it may be a to late, and I think its good practice to fit a back up safety device on solid fuel boilers regardles of whether the instructions say you need one or not.
Hi, Surely this subject has been aired. Or is it forums are getting short of work like the plumbing community?
Reply to the thread, titled "wood boiler stove installation" which is posted in Boiler Advice Forum on Electricians Forums.
