View the thread, titled "woodburning stove" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
jambo
hey guys got a job to view on fri installing a woodburning stove its not controlling the heating or hot water just to give off heat and for decrotive purposes any one had dealing with these should be a good job there is no origonal chimney in the room so out the wall with that just not sure on regs how high the terminal has to be above building any advice appreciated
You must be HETAS certified to install it, and if you are, you won't need to be asking the question as you should already know the answer.
no i am not never knew there was a qual to do this cheers for that bud guess i wont be doin that job
Reply to the thread, titled "woodburning stove" which is posted in UK Plumbers Forums on Plumbers Forums.
