F
FabreGAS
Looking for some help with a reoccurring problem with my 'pain in the a$$' boiler.
Fan seized a few months back - replaced fan......
About 2 months later the boiler locked out again - replaced APS...again boiler was fine for a few months until it locked out again. I am able to fire up boiler by removing combustion cover and sucking +ive tube before replacing tube onto fan venturi and quickly replacing combustion cover. (boiler won't spark with combustion cover off)......or I can activate APS from above boiler without taking combustion cover off.
When fired back up the boiler will only run until it reaches temp then when it tries to go through the ignition sequence again, it locks out.
THE FAN IS CONSTANTLY RUNNING - EVEN AFTER THE POWER IS CUT THEN TURNED BACK ON.
Pcb changed just a couple of years ago also!!!
Thanks in advance for any advice.
