Worcester 28i junior no hot water, sometimes
View the thread, titled "Worcester 28i junior no hot water, sometimes" which is posted in Bathroom Advice on UK Plumbers Forums.
W
wussel
I have a Worcester Bosch 28i Junior. Central heating works fine. Hot water doesn't work occasionally. The red flashes light quickly when this happens, holding it down resets everything and usually starts the hot water, sometimes it takes a couple of goes.
This hasn't been too much of a problem since moving into the house 2 years ago, it only happens once every couple of months, and then tends to only happen in chilly weather ie less than +10c.
Yesterday it happened everytime we demanded hot water, so appears to of suddenly got worse, but was fine for my wash this morning.
I want to get this problem sorted before it compleatly breaks forever. I havn't gone through the fault finding in the service instructions yet, becasue it is so intermittant.
Any thoughts?
I could be completely wrong in saying this but if your heating is working then the boiler is obv igniting. If boiler isn't igniting when you turn the hot tap on then it maybe that your Flow switch is faulty. To be sure though I'd get someone out to have a proper look at it.
I'm reluctant to call out a heating engineer, if it is going to be something easy and cheap to replace like the DHW sensor.
Following the basic fault finding guide in the manual won't help diagnose the correct item failing, it is too intermittant, that the fault finding guide will always suggest it is the pcb or harness.
Is it possible it is just something simple like the wind blowing the wrong way into the flue?
Your dangerous
Get an engineer in
I'm sorry, I know my limits, I won't attempt anything dangerous. If needed I will always get help and am willing to pay for it.
I am a licensed aircraft engineer, I know how to fault find complicated systems. Changing a sensor is well within my capability. I only wanted to know peoples thoughts what the likely failed compent might be.
Like I said, I know my limits, I only asked for advice. From that advice i'd weigh up the job and then get a technician in if it was above my ability.
At least after using this forum i'd hope to have a heads up as to what the actual failure could be, before they change the PCB and all the other non essiental work after being called back half a dozen times to fix the same fault.
At the moment I do not need to know how a gas tightness test is performed exactly. I will never need to know how to do it. I know my limits, you don't
Do you know the workings of a boiler? How do you know changing that sensor will not affect the combustion of the boiler?
Get in a Breakdown Engineer from a reputable firm and he should know what he is doing. These are in general not too bad to fault find.
How do you know your limits when it comes to working with a gas boiler. Are you aware of what work can be carried out on a boiler before you need to confirm the gas consumption and combustion process has not been affected?
QUOTE]
It isn't even lighting when this fault happens. So the combustion isn't an issue at all.
This is getting silly.
Thankyou jamino92, you were the only person who actually tried to help. Everyone else did the usual forum thing and flamed the newbie for not knowing as much as the "experts"
Moderators feel free to delete my account, I won't be back
There is no anger here
We are just trying to protect you from yourself
The reason we have to go through many years of training is to save lives
Good luck thou
Internet will be the best place to buy your bits
And don't worry about the red seal!
Reply to the thread, titled "Worcester 28i junior no hot water, sometimes" which is posted in Bathroom Advice on Plumbers Forums.
wussel,
SimonJohns,
