You get a wall plate included,time clock extra,if you are doing straight swop,note the flue is off centre
There are doing a cheaper eco combi range,this has no wall plate and you have to purchase fittings to flow and return and cold water isolation ,also just standard flue and elbow supplied,no other flue arrangement recommended on this model
I use HPS in london,if you ring Rehema they will give you any local stockest
If fitting for first time,read up on start up sequence when first power up
do they have a built in filling loop and by-pass?? i also see they do a wall plate and pipework tails to take all the pipework up and behind the boiler which could be handy given the space i have.
Reply to the thread, titled "worcester 28i junior or rehema avanta28c?" which is posted in UK Plumbers Forums on Plumbers Forums.
