View the thread, titled "Worcester 28i junior rsf air switch wont kick in" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
A
arty21
I have a 28i junior rsf(pre-condensing) The board fuse blue the other night so I replaced it and it blue again As I had come across this problem before on customers boilers I unpluged the fan from the board and the fuse said ok So I replaced the fan. The boiler fired ok but next morning the timer had switched it on but it had not fired. The fan and pump where running but the spark igniter had not operated. I tapped the air switch, nothing, I removed the red pipe and blue down it and replaced it and the boiler fired. I thought I had probably dislodged some muck and put it back together. The same evening the same thing happened. I remove the pipe and replaced it and the boiler fires. I replaced the switch. Next morning the same thing happened again. So new fan, new pressure switch and I have to remove and replace the red pipe from the air switch to get the boiler to fire. Once the boiler is working, if it cuts off on the thermostat it will fire again. If it cuts of on the timer then it wont work again. I am at a loss as to why. Can anyone help.
I am a gas safe registered engineer with 15 years experience in boiler repairs and yet this has got me puzzled.
Thank you
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location - [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/ce...ed-advice.html (notice gas safety related advice)
Reply to the thread, titled "Worcester 28i junior rsf air switch wont kick in" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
