View the thread, titled "Worcester 28i rsf combi no heating but hot water ok" which is posted in Bathroom Advice on UK Plumbers Forums.
L
lunno55
pressure has dropped below 1 bar, heating has stopped working but hot water ok, what do I need to do to get the heating going again and pressure back up? thanks
fill it back up from the filling loop which in your case could be a plastic plug in fixed to the back of the bottom panel
Yes thanks have have now done that, just moved in to house, previous owners had blocked in filler tap! doh!
Can't find the unit reset switch either?, I have switched the mains electricity supply off and on but the heating has not fired up, hot water working ok
Thanks again
Similar to the above but ch and water ok. Radiators much hotter than usual. Pressure has dropped to very low. How do I top up pressure to red line? Thanks for any help
Reply to the thread, titled "Worcester 28i rsf combi no heating but hot water ok" which is posted in Bathroom Advice on Plumbers Forums.
