View the thread, titled "Worcester 35/ remeha 35kw boilers" which is posted in Boiler Advice Forum on UK Plumbers Forums.
southcoastboile
Will any of the above boilers supply 2 mixer showers at the same time? without making the water in the other one go cold.
I may not be exact on the kw rating but will only be slightly out.
35kw is around 15l min (not exact) so if you put 7.5l min or lower restricters you should be ok.
Thanks Roger, I understand what you are saying as in half the amount of flow rate to each shower. Does that mean you would put restrictors in bar mixers? also 7.5 litres will be really poor for a shower wont it? Thanks
Don't forget you will only be restricting the hot water supply you'll be adding cold also, but you are right it won't be as good as a stored hw system
Okay thanks, were do the restrictors go and what do they look like? I pressume they must go were the filters on a bar mixer would be. Also she has bath taps with a hose off the top for one of the showers so were would you put the restrictor on that?
Reply to the thread, titled "Worcester 35/ remeha 35kw boilers" which is posted in Boiler Advice Forum on Plumbers Forums.
