M
mikeyc
Hi chaps, just been to a Worcester 350, fires up ok from first time central heating demand. Once the boiler gets up to temp and starts to cycle it just continues to cycle with pump running but does not go through the motions of going to ignition again - no overheat or anything and no lockout as such. The customer then has to turn off the boiler at the programmer and then back on and the boiler fires up on the button until it gets up to temp and cycles again.
Called technical and was told by an unconvincing techy that he thinks the sequence PCB is to blame.
Anyone else had this or have any other ideas? any help greatly appreciated
