Guest viewing limit reached
Worcester 38 CDi Classic combi whistling noise
View the thread, titled "Worcester 38 CDi Classic combi whistling noise" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt06
Hello, fitted worcester 38CDi classic combi yesterday, this morning customer switched it off as it was whistling/humming quite loudly
It seems to be when the fan runs at a certain speed
Fine all the other times
Called WB tech got passed to 3 people 3rd said it may be Membrane where air/gas mix sending a technician out on Monday to check
At first i thought could be the case not fitted properly and vibrating, It does it with the front cover off but it isn't quite so loud
Just wondered if anyone else has had this issue / Any thoughts
as far as i can see there is enough clips on the pipes, theres only about 2 foot between bottom of boiler to work top 2 clips on each pipe in this space and hot, cold and gas go below the worktop which i don't know how many clipsare on these , rest go up the wall in a cupboard which is clipped every meter and then through the ceiling joists
What was your combustion readings like , and the gas rate test was that satisfactory ?
Register plate, or membrane if you like sometimes go through ant touch the fan blades.
Reply to the thread, titled "Worcester 38 CDi Classic combi whistling noise" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt06,
Kevin D,
