G
golffan
Hi All, Ive been doing a lot of reading about the Greenmaster Junior and it appears that pressure problems are not a rare occurance!
The pipe work to the boiler is all exposed, well 90% is (we live in a flat) and there has been no sign of a leak in our flat, nor from the neighbours below which suggests the fault is on the boiler.
The pressure relief valve and expansion vessel were replaced recently and it is definitely not either of these are both are working correctly, is there anything else that could be causing the problem?
I top up the pressure to 1.5 using the filling loop and it takes around 5 or 6 days the the pressure to drop to zero. Clearly it shouldnt drop but I have no issue topping it up every week, but I assume this will mean the boiler will need to be replaced faster than if it was working correctly.
Any help would be greatly appreciated.
