Fairly new condensing boiler Greenstar 18ri (with hot water tank). Away from house for a week. Left the C/H switch at 'ON' with the wired thermostat in hall at 15c. The H/W left 'off' . On return, house was very cold - less than 9c. Increased thermo in hall to 25c , waited & nothing happened. Checked that the settings were ok. Then as a last resort, i slightly moved the thermostat on the boiler 5mm clockwise & it came on !!. Problem solved I thought. after testing a few times satisfactorily, put hall thermostat back to 15c.
Came back 7 hours later and same thing had happened. Cold house. At some point it had failed to click in again.
As before, I increased the thermo on the boiler clockwise ---but this time, nothing happened at all. Eventually, while leaving the C/H switch at 'on' , I also turned the Water onto 'on'. This started the water heating but also got the central heating to start, as I noticed the radiators warming up.
Any ideas what the problem is ? Cant work out if it is the boiler, the setting controls panel (potterten) or the hall thermostat (which you can hear the clicking when you increase). Has happened a couple of times again in the last few days.
Any help appreciated before I call someone out .
