View the thread, titled "Worcester Bosch Greenstar 18riwater leaking from bottom" which is posted in Bathroom Advice on UK Plumbers Forums.
beeloyalist
My WB Greenstar 18ri has started to leak water from the bottom left hand corner , also lots of gurgling sounds last 24 hrs, is this the condensate pipe frozen as looked and no evidence that this is the cause 😕
Sounds like it is your condense, could be blocked though not frozen. They make an awful gurgling sound when the pipe is blocked/frozen. You could try pouring a kettle of water over the pipe if it accesbile. If not call out a GSE and get it checked over properly. Also get it lagged if its not already
Reply to the thread, titled "Worcester Bosch Greenstar 18riwater leaking from bottom" which is posted in Bathroom Advice on Plumbers Forums.
