L
loziv
Hi
With a Worcester Bosch system boiler (its new just 4 years old and a Greenstar 30CDi ) what is the best set up to have it with an unvented hot water cylinder or a vented hot water cylinder (which is what we have at present) ?
Because we are having problems with the air getting into the shower supply from the pump I think because its draining the hot water cylinder quicker than the cold water storage tank in the loft can replace it with, and the volume of water in the storage tank is not enough to create enough header pressure in the cylinder which is causing the air in the pipes?
Does this sound feasable?
The the other reason why we are now looking at getting an unvented hot water cylinder is because it will get rid of the storage tank in the loft and we can also get rid of the old hot water cylinder in the airing cupboard in the bathroom freeing up space, as the unvented hot water cylinder could be re-sited downstairs in a room where the boiler currently is in the garage.
How much work is this likely to be and what would be rough costs in South Wales, I have also read the plumber needs to be G3 accredited to fit unvented cylinders.
Many thanks
Lauren
Many thanks
Lauren
