I'm wondering if anyone knows of a mod that can be done to the above boiler to enable the boiler to be pressurised without having to use the key method which is a pain in the a##e
He wanted to fit the internal one mate. So yes, there is. If he wants an external then obviously not.Drain system. Fit external filling loop water main to return pipework. Add enough inhibitor through a rad or similar and fill up with water. No need to be gas safe to do this one.
Cheers for changing your wording to this method. It is appreciated.Drain system. Fit external filling loop water main to return pipework. Add enough inhibitor through a rad or similar and fill up with water. No need to be gas safe to do this method.
Reply to the thread, titled "Worcester Bosh Greenstar 30si filling loop" which is posted in UK Plumbers Forums on Electricians Forums.
