View the thread, titled "Worcester compact" which is posted in UK Plumbers Forums on UK Plumbers Forums.
hammers4spanner
Subscribed
What do you lot make of this boiler ?
Fitted first one today not sure if the service panel was just flimsy pap or it was me not being use to it .The flue turret connections were very flimsy as well screwing the turret down sheared off the connection underneath very easy .
They normally like this??
Very good and normally they will only pop off if turned / miss aligned and I think very good boilers but that's me
The front flap is flimsy tat. The 30,000 screws that you need to remove and put back are a pain in the bum. And never liked the flue set up.
I also find you need to have the fingers of a 5 year old to get to the prv and don't get me started on the condense conection!
Must say at one point it felt like i was taking the boiler apart rather than installing it.
You fit a lot on contract?
I have only fitted one, got to service it next wee and I'm not looking forward to it
went to worcester boiler course and factory trip.....they showed us how easy it was ...if you know how . Is easier if you follow there steps.
Doesn't that defeat the idea tho having to do a course to be shown how to fit one ?
Most other manufacturers you just throw boiler at wall and plumb
The blow off is easy cable tie the brass nut so you have somthing to grab and just pull the cable tie round , doesn't need to be more than hand tight
Regarding the screws you don't need to take / put in more than 10
To have to put a cable tie on a nut of a top end boiler is a pretty poor show in my opinion.
Only problem I have had on the few I have fitted is the poxy clip that goes into expansion vessel, must be doing it wrong, Cant seem to get the bung out without taking clip out fully, and then trying to get back in once on the wall with long nose pliers.
pull clip out until it stops and lift the bung out, may need a wiggle but should come out with clip in
Do it on the ground before lifting the boiler, the c clip holds in place, should never pull out fully
Like this, I always do it before the boiler goes on the wall. Then its just a case of releasing the screw and vessel should drop into place then push the clip back in.
Thanks guys |I also do it on ground before it goes on the wall, last one the clip got wedged in between the pump and the plate, took me longer to fish that out than to hang boiler and put flue and condense in, trouble with have fingers like sausages I suppose.
Reply to the thread, titled "Worcester compact" which is posted in UK Plumbers Forums on Electricians Forums.
