View the thread, titled "Worcester Danesmore Oil boiler won't fire up after draining system to remove radiator" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
rico260z
Hi, after draining and refilling my system (to replace a radiator) my boiler no longer fires up but it DOESN'T lockout either. When I turn the power back on it sounds as if it's starting up (fuel pump etc starts making a noise) but don't hear it try to ignite and then it just sits there doing nothing with the on led's lit on the control panel. Think the boiler is a 15/19 model. Nothing was touched on the oil side of things so can only assume there is airlock somewhere but I bled the 3 bleed screws I could see in the boiler itself and the pump. Anyone any ideas what I've done wrong?? thanks
Re: Worcester Danesmore Oil boiler won't fire up after draining system to remove radi
Is there any heat at all in the boiler?
Tried the over heat reset on the under side of the main control panel
No the boiler doesn't have any heat at all as it doens't fire up at all when turned on. Is the overheat reset different from the reset but that you press when it locks out due to low pressure or if there's problem with the oil? If so I'll have look for that tonite then
Its been two weeks, get an engineer before it starts to get cold and our availability decreases 🙂
Found the overheat reset and once I pressed that the boiler locked out and the usual lockout reset button lit up. after 5 mins I pressed that and happily the boiler fired up and seems to be fine now.
Reply to the thread, titled "Worcester Danesmore Oil boiler won't fire up after draining system to remove radiator" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
rico260z,
rico260z,
